PhilQ
Aug 15, 2019Aspirant
Telephone Connection
I purchased and installed the Orbi to take the place of the cox panoramic wifi modem but I missed the fact that our home telephone was also plugged into the cox wifi modem. I really like the Orbi bu...
Tjharris6
Aug 15, 2019Guide
We have our phone line hook to a Verizon wireless home phone connect that has worked pretty welll. I would suggest you keep the home phone connect away from the orbi though.
Aug 16, 2019Guru - Experienced User
Orbi system doesn't support any phone line support. The CM1150v cable modem does.
Tjharris6 wrote:We have our phone line hook to a Verizon wireless home phone connect that has worked pretty welll. I would suggest you keep the home phone connect away from the orbi though.
