bentwookie
Mar 19, 2018Guide
Tell the Wire Cutter to reconsider their recommendation of the Orbi
I bought the Orbi 3 pack at Costco on the recommendation of the Wire Cutter. It might have been a fine product then, but it's garbage now (and has been for months). I've reached out to the review sit...
Mar 20, 2018Guru - Experienced User
Mines been working great as well, however new to the Orbi scene. Been online for two months solid. It's not always a HW or FW issue. There are other factors that can cause routers and wifi not to work well, theres environment, configuration and user set up that can impact how well all this works. ALL FW versions are still available from NG support. NG just pulled the recent one from being automatically upgraded. It's still available for use. Users and NG support need to troubleshoot where issue are present to really find out where the real problem is, where it be HW or otherwise.
The article and recommendation is valid.
