bentwookie
Mar 19, 2018Guide
Tell the Wire Cutter to reconsider their recommendation of the Orbi
I bought the Orbi 3 pack at Costco on the recommendation of the Wire Cutter. It might have been a fine product then, but it's garbage now (and has been for months). I've reached out to the review sit...
Starbucky
Mar 20, 2018Apprentice
Aren't the Dlink COVR products pretty new to the mesh game?
I did alot of research too before buying Orbi and never ran into a Dlink solution.
JeremyWxB
Mar 20, 2018Guide
My Orbi is great. I just purchased another set for my holiday home. So, it’s not a universal problem.
- Brain29Mar 20, 2018Apprentice
Wish I had an Orbi that worked where do I find one ??
ever since 2.1 I have constiant disconnects and straight up router freezing/locking up
moved back to 2.0.1.4 and the freezing continued every day I must resetstart at least once something that never happened the first month I had Orbi (makes remote connection very fun wondering why my server won't ping back)as for reviews I bought mine because of the raving reviews too but I found the orbi to be extremly lacking settings
This is my frist netgear product that is managed and I have not been impressed by any means
- its very sad because this is one of the only systems that has 4 lan ports on both units could have helped allot.
maybe 2.2 will be amazing but because it has been so long for an update they probally found a problem much bigger then code that is effecting "most of us" - FURRYe38Mar 22, 2018Guru - Experienced User
Hopefully soon, the next FW update will be available.
