rdgallo
Mar 28, 2023Aspirant
Temporarily Disable 5G on Orbi RBR 50
I have some new Arlo cameras that require I have my iPhone 13 Pro and the new cameras on the 2.4g frequency in order to set them up. How can I temporarily disable the 5g on my Orbi RBR50 and its sat...
michaelkenward
Mar 30, 2023Guru - Experienced User
rdgallo wrote:
As far as connecting to the network, I have received info saying I have to have the camera and the iphone connected to 2.4g when setting up and other info that says that is not true.
If in doubt, use 2.4 GHz.
The problem with WiFi range is that most routers will have the same reach. That's down to the WiFi standards and the radiation levels they are allowed to transmit.
One thing you can, set the device up close to the router and then to move it to the required location after you have got it working.
I have cameras working well about 25 metres from the nearest WiFi.
CrimpOn
Arlo has so many camera models. Which camera is this?
- michaelkenwardMar 30, 2023Guru - Experienced User
- CrimpOnMar 30, 2023Guru - Experienced User
Sorry not to be specific. Which model of Arlo camera is the Original Poster (OP) trying to connect to Orbi WiFi?
- rdgalloMar 30, 2023Aspirant
I have the Pro 5s.
- KevinLiTMar 30, 2023NETGEAR Moderator
Hello rdallo,
Welcome to the NETGEAR Community!
I understand that you would like to disconnect the 5GHz network band on your RBR50 to connect your security cameras. Unfortunately, the network bands on the RBR50 cannot be disabled. Connecting your cameras to the guest network or turning down the wireless signal may help your security cameras establish a network connection.
Best,
Kevin
Community Team
rdgallo wrote:
I have the Pro 5s.
Please see this web page:
https://kb.arlo.com/000062917/How-does-the-Arlo-Pro-5S-Camera-use-5GHz-Wi-Fi-networks
Notice this sentence:
This, there is zero need to do anything to the Orbi WiFi system.
I read that about the Pro 5S and was told that by one Arlo Rep. The next time I talked with Arlo, I was told the exact opposite (have to connect via 2.4g). I am going to attempt to hook up a camera tomorrow and see how it goes. As I mentioned before, I am not too sure some of the problem, if not all of it, is my network strength in the area I want the camera. I am going to move my satellite nearer that location to see if it makes a difference. I appreciate all the responses on here and will report back on how I do tomorrow. The one reply I got was to connect them via my guest network, which I can do, but am not sure why that would be different than using the regular network. Thanks again.
- Mikey94025Mar 30, 2023Hero
Yes just go ahead and try to connect your 5S camera to your Orbi network using your phone (normally connected to the Orbi). If you are not able to connect your new camera, do not assume yet that the problem is because of 2.4Ghz vs. 5Ghz.
Collect screen shots of the app trying to find the new camera and report exactly what error message you are encountering that is preventing the setup. These details will enable the community to help you (whether it's the Arlo community form or the Orbi community form here).
- rdgalloApr 06, 2023Aspirant
I ended up returning my Arlo Pro 5S cameras and purchased the Pro 4 cameras. I think Arlo has issues with the 5S cameras as I could never get them to work with my network. The Pro 4's connected easily and worked well except in the areas I lacked good wifi signal. I was going to update my Orbi RBR50 system with another Orbi system. I instead purchased an eero Pro 6E system that had the gateway router and two additional routers/satellites. I then added one more router/satellite to get the coverage all around the outside of my home. These were on sale at Best Buy (my total cost was about $587 plus tax minus about $70 trade in for my old Orbi system. Everything seems to be working fine now. Thanks to all that tried to help me.
