astake
Apr 11, 2020Aspirant
Temporary disable all 5GHz channels of Orbi router.
I need to disable the 5GHz channels in order to add new smart home devices which support 2.4GHz only. I have no clue to separate the SSID of 5GHz & 2.4GHz. I found the way to disable 5GHz temporary f...
ekhalil
Apr 11, 2020Master
It’s the same command, but you need to execute it on the Satellite. I guess that you only done this for the Router.
