DrKevorkian94
Jul 26, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
CrimpOn
Jul 26, 2019Guru - Experienced User
DrKevorkian94 wrote:So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found.
For instnce:
/bin/ash: config: not found
Additionaly i realized when I log in as admin my name in the promt is admin not root. Im on Mac OS running telnet though terminal. Any ideas why this is the case?
I guess you are trying the steps outlined in this post: https://community.netgear.com/t5/Orbi/How-to-disable-WiFi-on-the-Orbi-Router-or-Satellite/td-p/1677533 (read all the way through. there are corrections)
The credentials needed are still "admin" for the user ID and the administrative password. Interesting that your Orbi has a linux prompt of "#admin@", while my RBR50 shows a prompt of "root@".
I just typed the command on my Orbi and got my SSID. Did you type config get "w" lowercase L, underscore, "ssid"?
- DrKevorkian94Jul 26, 2019Tutor
I 100% have it correct "config wl_ssid" as you have stated. I keep gettign the error "/bin/ash: config: not found." I have looked though that post and those commadns also deliver the same error.
- CrimpOnJul 26, 2019Guru - Experienced User
Well now, this is just strange. Just to be onery, I logged in this time as "root" instead of "admin". TOOK IT! Here's proof:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.07.26 22:29:38 =~=~=~=~=~=~=~=~=~=~=~=
====================LOGIN=========================
Please enter account and password!!
RBR50 login: rootPassword:
BusyBox v1.24.1 (2019-06-28 21:18:41 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.MM NM MMMMMMM M M
$MMMMM MMMMM MMMMMMMMMMM MMM MMM
MMMMMMMM MM MMMMM. MMMMM:MMMMMM: MMMM MMMMM
MMMM= MMMMMM MMM MMMM MMMMM MMMM MMMMMM MMMM MMMMM'
MMMM= MMMMM MMMM MM MMMMM MMMM MMMM MMMMNMMMMM
MMMM= MMMM MMMMM MMMMM MMMM MMMM MMMMMMMM
MMMM= MMMM MMMMMM MMMMM MMMM MMMM MMMMMMMMM
MMMM= MMMM MMMMM, NMMMMMMMM MMMM MMMM MMMMMMMMMMM
(This is the OS/DK logo. Don't know why Notepad took all theextra spaces out)
MMMM$ ,MMMMM MMMMM MMMM MMM MMMM MMMMM MMMM MMMM
MMMMMMM: MMMMMMM M MMMMMMMMMMMM MMMMMMM MMMMMMM
MMMMMM MMMMN M MMMMMMMMM MMMM MMMM
MMMM M MMMMMMM M M
M
For those about to rock... (Chaos Calmer, r6043)
root@RBR50:/#And, I do not get "/bin/ash: <command> not found"
What I get is "-ash: <command>: not found
It had NEVER occured to me that the RBR50 and RBR40 would have a different shell.
Wow!
Was the root password the same as admin or something different?
