DrKevorkian94
Jul 26, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
CrimpOn
Jul 26, 2019Guru - Experienced User
DrKevorkian94 wrote:So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found.
For instnce:
/bin/ash: config: not found
Additionaly i realized when I log in as admin my name in the promt is admin not root. Im on Mac OS running telnet though terminal. Any ideas why this is the case?
I guess you are trying the steps outlined in this post: https://community.netgear.com/t5/Orbi/How-to-disable-WiFi-on-the-Orbi-Router-or-Satellite/td-p/1677533 (read all the way through. there are corrections)
The credentials needed are still "admin" for the user ID and the administrative password. Interesting that your Orbi has a linux prompt of "#admin@", while my RBR50 shows a prompt of "root@".
I just typed the command on my Orbi and got my SSID. Did you type config get "w" lowercase L, underscore, "ssid"?
DrKevorkian94
Jul 26, 2019Tutor
I 100% have it correct "config wl_ssid" as you have stated. I keep gettign the error "/bin/ash: config: not found." I have looked though that post and those commadns also deliver the same error.
- CrimpOnJul 26, 2019Guru - Experienced User
Well now, this is just strange. Just to be onery, I logged in this time as "root" instead of "admin". TOOK IT! Here's proof:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.07.26 22:29:38 =~=~=~=~=~=~=~=~=~=~=~=
====================LOGIN=========================
Please enter account and password!!
RBR50 login: rootPassword:
BusyBox v1.24.1 (2019-06-28 21:18:41 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.MM NM MMMMMMM M M
$MMMMM MMMMM MMMMMMMMMMM MMM MMM
MMMMMMMM MM MMMMM. MMMMM:MMMMMM: MMMM MMMMM
MMMM= MMMMMM MMM MMMM MMMMM MMMM MMMMMM MMMM MMMMM'
MMMM= MMMMM MMMM MM MMMMM MMMM MMMM MMMMNMMMMM
MMMM= MMMM MMMMM MMMMM MMMM MMMM MMMMMMMM
MMMM= MMMM MMMMMM MMMMM MMMM MMMM MMMMMMMMM
MMMM= MMMM MMMMM, NMMMMMMMM MMMM MMMM MMMMMMMMMMM
(This is the OS/DK logo. Don't know why Notepad took all theextra spaces out)
MMMM$ ,MMMMM MMMMM MMMM MMM MMMM MMMMM MMMM MMMM
MMMMMMM: MMMMMMM M MMMMMMMMMMMM MMMMMMM MMMMMMM
MMMMMM MMMMN M MMMMMMMMM MMMM MMMM
MMMM M MMMMMMM M M
M
For those about to rock... (Chaos Calmer, r6043)
root@RBR50:/#And, I do not get "/bin/ash: <command> not found"
What I get is "-ash: <command>: not found
It had NEVER occured to me that the RBR50 and RBR40 would have a different shell.
Wow!
- DrKevorkian94Jul 26, 2019Tutor
Was the root password the same as admin or something different?
- CrimpOnJul 27, 2019Guru - Experienced User
I entered the same administrative password using both user names ("admin" and "root")
Both ways, it said I was logged in as "root".
(Dumb me, I had never noticed that before.)
We have tons of users with Mac's on the forum. Surely this isn't one of those "Mac vs. PC" things or someone would have mentioned it already.
