DrKevorkian94
Jul 26, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
DrKevorkian94
Jul 26, 2019Tutor
I 100% have it correct "config wl_ssid" as you have stated. I keep gettign the error "/bin/ash: config: not found." I have looked though that post and those commadns also deliver the same error.
CrimpOn
Jul 26, 2019Guru - Experienced User
Well now, this is just strange. Just to be onery, I logged in this time as "root" instead of "admin". TOOK IT! Here's proof:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.07.26 22:29:38 =~=~=~=~=~=~=~=~=~=~=~=
====================LOGIN=========================
Please enter account and password!!
RBR50 login: root
Password:
BusyBox v1.24.1 (2019-06-28 21:18:41 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
MM NM MMMMMMM M M
$MMMMM MMMMM MMMMMMMMMMM MMM MMM
MMMMMMMM MM MMMMM. MMMMM:MMMMMM: MMMM MMMMM
MMMM= MMMMMM MMM MMMM MMMMM MMMM MMMMMM MMMM MMMMM'
MMMM= MMMMM MMMM MM MMMMM MMMM MMMM MMMMNMMMMM
MMMM= MMMM MMMMM MMMMM MMMM MMMM MMMMMMMM
MMMM= MMMM MMMMMM MMMMM MMMM MMMM MMMMMMMMM
MMMM= MMMM MMMMM, NMMMMMMMM MMMM MMMM MMMMMMMMMMM
(This is the OS/DK logo. Don't know why Notepad took all the
extra spaces out)
MMMM$ ,MMMMM MMMMM MMMM MMM MMMM MMMMM MMMM MMMM
MMMMMMM: MMMMMMM M MMMMMMMMMMMM MMMMMMM MMMMMMM
MMMMMM MMMMN M MMMMMMMMM MMMM MMMM
MMMM M MMMMMMM M M
M
For those about to rock... (Chaos Calmer, r6043)
root@RBR50:/#
And, I do not get "/bin/ash: <command> not found"
What I get is "-ash: <command>: not found
It had NEVER occured to me that the RBR50 and RBR40 would have a different shell.
Wow!
- DrKevorkian94Jul 26, 2019Tutor
Was the root password the same as admin or something different?
- CrimpOnJul 27, 2019Guru - Experienced User
I entered the same administrative password using both user names ("admin" and "root")
Both ways, it said I was logged in as "root".
(Dumb me, I had never noticed that before.)
We have tons of users with Mac's on the forum. Surely this isn't one of those "Mac vs. PC" things or someone would have mentioned it already.
- ekhalilJul 27, 2019Master
DrKevorkian94 wrote:......... Im on Mac OS running telnet though terminal. Any ideas why this is the case?
MacOS -by default- does not support telnet any longer through terminal (since MacOS Mojave, I think).
What have you installed to get telnet to work? I gues the issue is there, unless you're using an older MacOS
Here is how I got telnet to work on my Macbook: http://osxdaily.com/2018/07/18/get-telnet-macos/
