DrKevorkian94
Jul 26, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
CrimpOn
Jul 27, 2019Guru - Experienced User
Is there anything else 'different' about when you log in? For example, the first thing I see is this:
BusyBox v1.24.1 (2019-06-28 21:18:41 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
And, my prompt comes up as "root@RBR50#"
Like, even "help" doesn't work?
- DrKevorkian94Jul 27, 2019Tutor
Help does not work. This is my login:
- CrimpOnJul 27, 2019Guru - Experienced User
Wow, am I slow. CBR40, as in "built-in cable modem" Orbi. (The only model with one) And, you've probably had it more than 90 days, so Netgear support won't answer even a simple question.
Have you tried logging in as "root"?
