DrKevorkian94
Jul 26, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
DrKevorkian94
Jul 27, 2019Tutor
Help does not work. This is my login:
CrimpOn
Jul 27, 2019Guru - Experienced User
Wow, am I slow. CBR40, as in "built-in cable modem" Orbi. (The only model with one) And, you've probably had it more than 90 days, so Netgear support won't answer even a simple question.
- CrimpOnJul 27, 2019Guru - Experienced User
Have you tried logging in as "root"?
- DrKevorkian94Jul 27, 2019Tutor
Yup had it a while now with no issues, I have a device that requires an initial connection to a 2.4g network. Just wanted to turn off the 5g radio and trun it back on after. If I try logging on as root with mny saem admin passowrd it does not work. I cant think of any other password besides, root, and password. Those have not worked either =.
I agree. The crazy thing is that logging on with "admin" and the Orbi administrative password is successful, but then (1) the prompt is not "root" and (2) BusyBox commands are not recognized. (even the error message is different from mine).
