DrKevorkian94
Jul 27, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
CrimpOn
Jul 27, 2019Guru - Experienced User
Have you tried logging in as "root"?
DrKevorkian94
Jul 27, 2019Tutor
Yup had it a while now with no issues, I have a device that requires an initial connection to a 2.4g network. Just wanted to turn off the 5g radio and trun it back on after. If I try logging on as root with mny saem admin passowrd it does not work. I cant think of any other password besides, root, and password. Those have not worked either =.
- CrimpOnJul 27, 2019Guru - Experienced User
I agree. The crazy thing is that logging on with "admin" and the Orbi administrative password is successful, but then (1) the prompt is not "root" and (2) BusyBox commands are not recognized. (even the error message is different from mine).
- DrKevorkian94Jul 27, 2019Tutor
This is what I get if I run "busybox" , the commanbds listed there work. I dont see get or config
"config" is not in my BusyBox, either. My BusyBox is v1.24.1 and yours is v1.23.2 My BusyBox has 99 commands that are not in yours, while yours has 8 commands that are not in mine. There are 109 commands that are in both. Who would have thought the Netgear team developing Orbi would use entirely different versions of BusyBox for different products?
Can you log into the Orbi, change directories to /bin and list all the files? i.e.
cd /bin
ls -l
