DrKevorkian94
Jul 27, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
DrKevorkian94
Jul 27, 2019Tutor
Yup had it a while now with no issues, I have a device that requires an initial connection to a 2.4g network. Just wanted to turn off the 5g radio and trun it back on after. If I try logging on as root with mny saem admin passowrd it does not work. I cant think of any other password besides, root, and password. Those have not worked either =.
CrimpOn
Jul 27, 2019Guru - Experienced User
I agree. The crazy thing is that logging on with "admin" and the Orbi administrative password is successful, but then (1) the prompt is not "root" and (2) BusyBox commands are not recognized. (even the error message is different from mine).
- DrKevorkian94Jul 27, 2019Tutor
This is what I get if I run "busybox" , the commanbds listed there work. I dont see get or config
- CrimpOnJul 27, 2019Guru - Experienced User
"config" is not in my BusyBox, either. My BusyBox is v1.24.1 and yours is v1.23.2 My BusyBox has 99 commands that are not in yours, while yours has 8 commands that are not in mine. There are 109 commands that are in both. Who would have thought the Netgear team developing Orbi would use entirely different versions of BusyBox for different products?
Can you log into the Orbi, change directories to /bin and list all the files? i.e.
cd /bin
ls -l
- DrKevorkian94Jul 28, 2019Tutor
Aint that crazy right?! Abd yes I can, I did however do that and did not see the comands i was looking for:
lrwxrwxrwx 1 root root 7 Jun 26 00:34 ash -> busybox
-rwxrwxr-x 1 root root 265 Jun 25 23:25 board_detect
-rwxr-xr-x 1 root root 378781 Jun 26 00:05 busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 cat -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 chgrp -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 chmod -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 chown -> busybox
-rwxr-xr-x 1 root root 55315 Jun 27 06:41 circled
-rwxrwxr-x 1 root root 3311 Jun 25 23:25 config_generate
lrwxrwxrwx 1 root root 7 Jun 26 00:34 cp -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 date -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 dd -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 df -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 dmesg -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 echo -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 egrep -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 false -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 fgrep -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 fsync -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 grep -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 gunzip -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 gzip -> busybox
-rwxrwxr-x 1 root root 1550 Jun 25 23:25 ipcalc.sh
lrwxrwxrwx 1 root root 7 Jun 26 00:34 kill -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 ln -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 lock -> busybox
lrwxrwxrwx 1 root root 8 Jun 27 06:41 login -> login.sh
-rwxrwxr-x 1 root root 424 Jun 25 23:25 login.sh
-rwxr-xr-x 1 root root 828 Jun 27 06:41 login_telnet2
lrwxrwxrwx 1 root root 7 Jun 26 00:34 ls -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 mkdir -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 mknod -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 mktemp -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 mount -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 mv -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 netmsg -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 netstat -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 nice -> busybox
-rwxr-xr-x 1 root root 117320 Jun 26 00:14 opkg
lrwxrwxrwx 1 root root 7 Jun 26 00:34 pidof -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 ping -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 ping6 -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 ps -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 pwd -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 rm -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 rmdir -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 sed -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 sh -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 sleep -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 stat -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 sync -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 tar -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 touch -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 true -> busybox
-rwxr-xr-x 1 root root 6555 Jun 26 00:13 ubus
lrwxrwxrwx 1 root root 7 Jun 26 00:34 umount -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 uname -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 vi -> busybox
lrwxrwxrwx 1 root root 7 Jun 26 00:34 zcat -> busybox
