DrKevorkian94
Jul 27, 2019Tutor
Tenet command: not found
So ive been attmeptign to disable the 5g network or seperate the 2.4g and 5 g networks but no mater command i run its not found. For instnce: admin@CBR40:# config get wl_ssid /bin/ash: config...
CrimpOn
Jul 28, 2019Guru - Experienced User
Our systems are not anything alike. I have no idea how they can be so different and perform the same functions.
Since we are not getting very far in this direction, maybe it would be useful to open a new post and ask for advice on getting the specific device to connect to Orbi. For example, when people began complaining about their "Smart Plug" needed 2.4G to connect, I purchased a bunch of them and found that they ALL connected just fine. Even the one that complained, "Must set phone to 2.4G!!!" I simply ignored the message, hit "Continue", and the plug worked.
It is well-established that it is not the presence of the Orbi 5G signal that interferes with the actual device. The device has only a 2.4G radio and thus is blissfully ignorant of 5G, just as it isn't bothered by 900MHz wireless phones or cell phone signals. Sometimes it is the smartphone app that is written poorly.
What is this thing?
Saurabh1990
Aug 14, 2019Aspirant
I just purchased this modem router. And tried to configure 2.4 and 5ghz separetely. I am also facing same issue. Were you able to resolve this issue?
