dlemke1
Aug 07, 2017Follower
Terrible satellite coverage - AC3000 RBK50
Anyone else have absolutely terrible satellite coverage with this system? I'm talking about a 1500 sq. ft. home total... router on lower level... satelite directly above on 2nd floor through normal wood flooring and carpet with a solid blue connection between the two and with a low to no wifi signal down a halway into a bedroom on the same floor as satelite. Have verfied current firmware version. Most frustrating is that they give you absolutely no way of contacting them... not even to submit a support ticket have I found for this product. Next move is to the general internet to hammer this product... So dissappointed. If you know of a fix... please help. Thank you!!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello dlemke1
something could be interfering with the connection where you have it placed have you tried different locations on the second floor?
DarrenM
