Saguarojoe
Jan 21, 2020Aspirant
Tesla goes to sleep
My Tesla Model 3 has no problem connecting to orbi when the car is awake however Teslas go into a deep sleep mode when parked after a few minutes. It disappears from the network in that state. If Tesl...
Jan 21, 2020Guru - Experienced User
Orbi isn't doing the reconnecting. The tesla is. If it wakes up, it'll connect (should). If you're selecting "update later" option when tesla sends you the update, the car should be waking to update at a later time.
Again, thats all said with a should. If you google "tesla not waking" theres a ton of posts.
Saguarojoe
Sounds logical except the car isn’t checking for updates, the factory is letting the car know there is an update and downloads it for the owner to install on their schedule.
