bsholbrook's avatar
bsholbrook
Apprentice
Jan 02, 2017
Testing with AirPlay Speakers
Yesterday I experimented with airplay speakers and orbi and found this out.... when speakers are connected to the router they work perfectly.  When they are connected to a satelite and the received communications traverses the backhaul problems start.  The Audio will dropout occasionally, which if very frustrating.  Anyone have airplay setups they are using?
  • Try setting your Advanced Wireless RTS to 2346. This is not the Orbi default.
  • Should have special died, and already set rts down from 2347 to 2346
