Raptor_XP
Oct 11, 2021Aspirant
The 2.7.3.22 automatic update just bricked my Orbi system. Now what?
Everything was working fine with my Orbi system, until the router decided to update itself to V2.7.3.22. Now all the wired Ethernet ports are broken and no longer provide any connectivity. I don't se...
Raptor_XP
The WiFi still works so I can access 192.168.1.1 and the Internet via WiFi. The Ethernet ports are all broken though, and I have about a dozen devices connected via wired Ethernet.
CrimpOn
Oct 11, 2021Guru - Experienced User
Could you humor me and report a few things:
- On the Orbi web interface at http://192.168.1.1
Click on the Advanced Tab
Click on the Blue Box under Internet Port titled "Show Statistics" and report how it describes the WAN and LAN ports. - If there are a dozen devices connected to the Orbi, then there must be at least one switch (maybe more?)
Many ethernet switches have tiny LED's on the ethernet jacks which indicate status (connected, rate, traffic, etc.)
What do the jacks that are connected to the Orbi display on their LED's? - Is it convenient to connect one of the ethernet devices directly to an Orbi LAN jack?
- What is the specific symptom that leads to the conclusion of "broken"? (message of "no internet"? unable to ping devices?, etc.)
Thanks
