darreln
Dec 10, 2018Aspirant
The case of the disappearing Sonos system...
I have a Sonos sound system, with 4 speakers and 1 Bridge (for HT). I have the RBR50 router with a satellite, and a RBW30 plug-in AP. Everything has been working flawlessly until recently. Starting a...
Dec 10, 2018Guru - Experienced User
How are the sonos connected? Wirelessly? Wired connections do anything different?
Lots of issues with Sonos devices and routers. Besure they aren't broadcasting there own wifi as well...
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only and not Auto.
ry disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Try setting a IP address reservation for the Sonos devices...
darreln
thanks for your reply. Here's my responses.
-all wirelessly. I don't have any wired connections nearby the speakers
-not sure what that means, do you mean that sonos speakers create their own wifi network? Don't see an option in their app for that..
-2,880 modern build, kills wifi dead. Hence the satellite & the plug-in satellite. been working just fine for a long time...
-router is in the wiring closet, satellite is upstairs and does show valid connection. plug-in is downstairs within 30 feet i'd say
-channel 3 for 2.4 (which I believe sonos uses).
-showing around 10-12...
-WPA2 is set
- that's a lot of settings to mess with, I'll take a look at those :)
- FURRYe38Dec 10, 2018Guru - Experienced User
Some Sonos do have there own broadcast wifi. Might check in to this to be sure.
"channel 3 for 2.4 (which I believe sonos uses)." Use channel 1, 6 or 11 on the Orbi.
https://community.netgear.com/t5/Orbi/Orbi-amp-Sonos-To-SonosNet-or-not/m-p/1476191#M19861
- darrelnDec 10, 2018Aspirant
Thanks!
I checked the sonos app, and SonosNet is using Channel 6, whereby Orbi was using Channel 3. I changed the Orbi channel anyways to Channel 1, but I am not sure that there was a conflict per se.
Ok, 3 isn't a primary channel, 1, 6 or 11 is. See if this does anything different...
