darreln
Dec 10, 2018Aspirant
The case of the disappearing Sonos system...
I have a Sonos sound system, with 4 speakers and 1 Bridge (for HT). I have the RBR50 router with a satellite, and a RBW30 plug-in AP. Everything has been working flawlessly until recently. Starting a...
darreln
thanks for your reply. Here's my responses.
How are the sonos connected? Wirelessly? Wired connections do anything different?
-all wirelessly. I don't have any wired connections nearby the speakers
Lots of issues with Sonos devices and routers. Besure they aren't broadcasting there own wifi as well...
-not sure what that means, do you mean that sonos speakers create their own wifi network? Don't see an option in their app for that..
-2,880 modern build, kills wifi dead. Hence the satellite & the plug-in satellite. been working just fine for a long time...
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
-router is in the wiring closet, satellite is upstairs and does show valid connection. plug-in is downstairs within 30 feet i'd say
-channel 3 for 2.4 (which I believe sonos uses).
-showing around 10-12...
What WPA security modes are you using? Try WPA2 and AES only and not Auto.
-WPA2 is set
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- that's a lot of settings to mess with, I'll take a look at those :)
Dec 10, 2018Guru - Experienced User
Some Sonos do have there own broadcast wifi. Might check in to this to be sure.
"channel 3 for 2.4 (which I believe sonos uses)." Use channel 1, 6 or 11 on the Orbi.
https://community.netgear.com/t5/Orbi/Orbi-amp-Sonos-To-SonosNet-or-not/m-p/1476191#M19861
- darrelnDec 10, 2018Aspirant
Thanks!
I checked the sonos app, and SonosNet is using Channel 6, whereby Orbi was using Channel 3. I changed the Orbi channel anyways to Channel 1, but I am not sure that there was a conflict per se.
- FURRYe38Dec 10, 2018Guru - Experienced User
Ok, 3 isn't a primary channel, 1, 6 or 11 is. See if this does anything different...
- st_shawDec 10, 2018Master
Use CH 11 for Sonos and CH 1 for Orbi, or vice versa. This is the only configurartion that will avoid channel conflicts. This is because Orbi uses 40 MHz channel width on 2.4.
Also, be sure to keep some distance between your Orbi units and any of your Sonos components. Orbi can saturate and interfere with Sonos radio comms, even if they are on separate channels.
Lastly, when using Sonosnet, you must have your Sonos devices distributed closely enough to each other, and powered on, in order to form a complete mesh network. The Sonos devices hop through each other to share data. They don't use your WiFi at all. If one or more of your Sonos devices are too far away from the others, they can drop of the network.
- JammasterCDec 10, 2018Star
I too was having Sonos dropouts.
I changed the channels on both(1 & 11), but still had issues.
I disconnected the Sonos bridge, went to Wifi mode and have not had a dropout yet.
