Tigana
Feb 19, 2020Aspirant
The devices connect via wifi to RBK50, but some show no internet connection.
SInce a couple of weeks I have got problems with my Orbi router. Devices connect easily, but some does not get internet connection, while some work fine. E.g. my iMac most often shoe no internet conn...
- Feb 19, 2020
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
Feb 19, 2020Guru - Experienced User
- TiganaFeb 20, 2020Aspirant
Thanks for your comments. I now have made a factory reset and so far so good it seems to work. :)
