sherveyjeff
Sep 08, 2020Apprentice
The dreaded Samsung Galaxy WIFI authentication error with ORBI
Ok for as long as I had my ORBI's (RBK53 - 1 Router 2 sats) (3- years+ now) and as long as I had Samsung Galaxy cell phones (S6, S7, S8, Note9) the Samsung Galaxy cell phones will randomly get the W...
Senpai_Ruku
Mar 18, 2021Aspirant
I have the same issue on my Galaxy A71, and I am using an Ubiquiti Unifi network, consisting of a UDM and a UAP IW-HD.
I find turning off and, on the Wi-Fi, usually fixes this. It's nothing to do with DHCP leases or the network configuration as when this issue occurs I can easily connect to another WLAN I have set up with identical radio and authentication settings to my main home network, it's just on a different VLAN.
sherveyjeff
Mar 18, 2021Apprentice
Try this bandaid... I dont notice the pain anymore of my cellphone with stuck "needs authentication" wifi
What I have found that helped to reduce the pain is: install "Wifi Automatic" by j4elin from the Google Play store.
In the App settings I used:
Turn Wifi on...
- When the device is unlocked
Turn Wifi off when...
- Screen is off (for at least 10 mins)
Also in you phone Wifi settings... the 3 dots - where you can go into your wifi advanced settings:
"Switch to mobile data" - On
"Turn on WI-Fi automatically" - On
It takes away some of the stuck "needs authentication" Wifi issues... where you get no data flowing to your phone until you reset your wifi
