jbartlett
Apr 22, 2021Follower
The Elusive Internet Drops - Wifi AND Ethernet
I have the RBK50 set (RBR50v2 and RBS50v2) on the latest firmware (V2.7.2.104). The router is in my family room on the 1st floor, and the satellite in the 2nd floor master bedroom on the opposite end...
Apr 22, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Try this?
Do you have Armor or Circle enabled?
