jmbarbs
Feb 10, 2017Apprentice
The end of iOS disconnections after changing one setting
After returning my orbi due to iOS disconnections I purchased a velop which I wasn't happy with. I decided to try orbi again and got a replacement. As with the first orbi unit, the disconnections ...
cue003
Have you had any loss in coverage or performance by reducing the transmit power control down to 25%? Is this something done on the router or the satellite or on all Orbis?
jmbarbs
Hi
not had any noticable loss in coverage. You get to the setting by going to orbi login, advanced, advanced setup, wireless settings then under 2.4ghz transmit control power select 25%.
i left the 5ghz wifi untouched at 100%
