jmbarbs
Feb 10, 2017Apprentice
The end of iOS disconnections after changing one setting
After returning my orbi due to iOS disconnections I purchased a velop which I wasn't happy with. I decided to try orbi again and got a replacement. As with the first orbi unit, the disconnections ...
jmbarbs
Feb 11, 2017Apprentice
The only reason I returned the velop was in my house it struggled to give a good connection at the far end (which I needed as have a external nest cam at that corner of the house). This was using a pack of 3.
Also I found the speed throughput much slower than orbi.
I think what I am learning from using these systems is that one system may work well In one persons house and behave completely different in another building, so I would say try the velop and see if it works for you (if you are sure that the orbi is not suitable in your environment).
jmbarbs
Also just a update my disconnections have started again. For the interim period until a update hopefully fixes, I'm considering turning off the wireless on orbi and put in AP mode. Turn the wifi back on my isp router/modem and then in the corner of my house where my sat is I'm going to plug in a airport express wired to the sat to try to get signal to my nest cam. I presume then I can also get the benefit of orbi speed from the main unit back to the sat and then hardwire Ethernet from the sat to my iMac in my office.
