jmbarbs
Feb 10, 2017Apprentice
The end of iOS disconnections after changing one setting
After returning my orbi due to iOS disconnections I purchased a velop which I wasn't happy with. I decided to try orbi again and got a replacement. As with the first orbi unit, the disconnections ...
nick776
Feb 11, 2017Guide
Why did you return the velop? Why didn't you like it? I'm going to be returning Orbi for Velop if they can't confirm wired backhaul is in the works for Orbi.
B747driver
Feb 11, 2017Star
nick776 wrote:Why did you return the velop? Why didn't you like it? I'm going to be returning Orbi for Velop if they can't confirm wired backhaul is in the works for Orbi.
1. The app, which is required for installation and everything else, is buggy as hell.
2. Nodes drop offline for no apparent reason. Reset and then it drops offline again 10 min later. Rinse and repeat.
3. Half of the time during a reset, a node would get "stuck" while trying to configure -----> start over.
4. Node relocation, channel optimization, system resets, etc. - all done several times several times to no avail.
5. Tech support was willing but unable to resolve anything. I spent several hours on the phone with them. Fix one problem and something else pops up.
6. Nest Cams dropped offline constantly and a few other devices had intermittent poor connections.
7. My Airport Extreme performed much better in every aspect. Why did I buy on this thing?
For $500, I expected it to pretty much work out of the box. It did not. A few tweaks here and there is one thing, but Velop required much more than that. My short term best case scenario was that it was going to consume a vast amount of time to keep it running. That was something I was not willing to tolerate. Long term worst case scenario was that I bought a system full of bugs, hoping it gets sorted one day out but never does. That wasn't acceptable either.
Long story short, I ended my frustration and returned it after two days. Maybe I got a lemon, I don't know. I really didn't care at that point. It left a very bad taste in my mouth. I don't know if you're experiencing other issues or if Orbi is simply missing a feature you desire, but personally, I would sit tight for a few more months before making the jump to Velop. Return Orbi if you must, but Velop is not ready for prime time IMO.
