jmbarbs
Feb 10, 2017Apprentice
The end of iOS disconnections after changing one setting
After returning my orbi due to iOS disconnections I purchased a velop which I wasn't happy with. I decided to try orbi again and got a replacement. As with the first orbi unit, the disconnections ...
andykerslake
Feb 13, 2017Star
I found that reducing the power setting to 25% helped, but did not fix the disconnects on an iPhone 6 with latest ios.
However I decided to switch off the 2.4ghz wireless and this has fixed all disconnect issues. I suspect it is to do with both the 2.4ghz and the 5.0ghz having the same SSID
- DarrenMFeb 14, 2017Sr. NETGEAR Moderator
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
Thank You
DarrenM
