jmbarbs
Feb 10, 2017Apprentice
The end of iOS disconnections after changing one setting
After returning my orbi due to iOS disconnections I purchased a velop which I wasn't happy with. I decided to try orbi again and got a replacement. As with the first orbi unit, the disconnections ...
andykerslake
Feb 13, 2017Star
I found that reducing the power setting to 25% helped, but did not fix the disconnects on an iPhone 6 with latest ios.
However I decided to switch off the 2.4ghz wireless and this has fixed all disconnect issues. I suspect it is to do with both the 2.4ghz and the 5.0ghz having the same SSID
DarrenM
Feb 14, 2017Sr. NETGEAR Moderator
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
Thank You
DarrenM
