jbc9727
Mar 25, 2020Follower
The LED of the satelites for my RBR40 are always orange
Hi All, I just bought my Orbi system last week. I put the main router in the living room and 2 satelites in 2 rooms respectively. Here comes the problem, my flat is like around 800 sq. ft., but b...
Mar 25, 2020Guru - Experienced User
800sq ft maybe to small of a area for the RBR and two satellites.
Factory reset and setup the RBS 1 at a time. Leave off other RBS. Just work with one RBS.
