audiostreamer
Jan 02, 2020Aspirant
The Orbi Home Wi-Fi challenge - so far is not going to win for me ....
I bought the Orbi RBK20's based on the Orbi Home Wi-Fi challenge - so I had nothing to lose if things did not work out. My main gripe is not being able to split the wireless streams into 2x SSIDs...
audiostreamer
Jan 03, 2020Aspirant
It's easy to get puzzled over this - I do too.
The Auralic does have an Ethernet port so I could use that option instead, you are right - it would effectivley give the Auralic a better antenna to work with as a bonus (and any other device that sits on the Hi-Fi rack requiring an Internet connection too - i.e. my Marantz NA7004 and many other streamers I am messing about with).
Anyway let me explain the Auralic and how it works ....
... the sensitive area with the Auralic Mini is the Apple Control app (called Lightning DS) when sending commands to the Mini such as, changing the volume control (sliding the volume up and down on the app) - changing from Internet Radio to Tidal etc - those sort of software controls / instructions. Why sensitive - because those controls required UDP packets which are not checked over IP when delivered. If UDP packets get dropped then the software control loses touch.
When the music actually streams it uses TCP packets - TCP packets get buffered and checked for delivery over IP, so are far more reliable (streaming music does not drop).
In my experience a good 5GHz wireless signal ensures better control of the Auralic Mini.
CrimpOn
Jan 03, 2020Guru - Experienced User
audiostreamer wrote:It's easy to get puzzled over this - I do too.
Ethernet sounds like a "win-win" to me, even better than 5G WiFi on the Auralic side. The control app can connect to the Orbi and from there it will be 5G backhaul and ethernet.
However, sometimes it is better to stop "beating a dead horse" and get on with life. Wish I could recommend a different product, but I only know the Nighthawk R7000, which was replaced by the Orbi because it didn't cover the house well enough, and the Orbi.
Good Luck!
