TMW949
Dec 01, 2022Follower
The Two SSIDs Thing
I have an RBR40 and two RBS20s. Orbi and my Nest Outdoor Camera can't maintain a connection. They are about a foot apart with only a pane of glass between them for testing. I think this is becaus...
Dec 02, 2022Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Move the camera farther away. 1foot is too close. 3-6 feet is starting distance between devices as Orbi systems.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
TMW949 wrote:
I have an RBR40 and two RBS20s. Orbi and my Nest Outdoor Camera can't maintain a connection. They are about a foot apart with only a pane of glass between them for testing. I think this is because the Nest keeps promoting itself to 5 GHz and dropping out. I need a robust connection (distance - not speed) here. The latest firmware for the Orbi has discontinued the Telnet access feature, so the Telnet hack to configure two SSIDs won't work without downgrading firmware, which I am reluctant to do. I need to replace the Orbi and I keep getting recommendations to stay with Netgear. (Is this insanity?) I need to know which (if any) modern Netgear routers support separate SSIDs for 2.4 and 5 Ghz in the application user interface. Nearly all of my 20+ devices connect to the RBR40, so mesh may not be a requirement. The house is 2400 square feet on two floors with a stucco exterior.
