TMW949
Dec 01, 2022Follower
The Two SSIDs Thing
I have an RBR40 and two RBS20s. Orbi and my Nest Outdoor Camera can't maintain a connection. They are about a foot apart with only a pane of glass between them for testing. I think this is becaus...
Mikey94025
Dec 02, 2022Hero
TMW949 wrote:I need to know which (if any) modern Netgear routers support separate SSIDs for 2.4 and 5 Ghz in the application user interface.
The RBKE963 wi-fi 6e, top of the line Orbi router does have a separate IoT SSID that you can configure separately to be only 2.4Ghz. It's a convenient way to publish a 2.4Ghz-only SSID for the subset of IoT devices that otherwise struggle during initial setup or otherwise.
Separately, is it possible that your satellites are too close and interfering with the RBR wifi? You can do a quick experiment by disabling the RBSs and seeing if your Nest camera still has issues. I have 7 Nest cameras and they did not have any issues connecting to the 5-series, 7-series, 8-series, and 9-series Orbi routers I've owned over the years.
