gordongekko
Apr 21, 2019Aspirant
The wifi connections on my orbi system keeps dropping
Every 4 to 5 minutes, my orbi RBR50 AC3000 system diconnects and connects the wifi on both the 2,4ghz and the 5 ghz band. I have the newest sw installed on the router and satelite. I bougth my orbi ...
gordongekko
Apr 22, 2019Aspirant
FW is V2.3.1.48 on both satelite and router, this is the newest.
The Mfr is Alcatel lucent, the model is G-11G-P
My hose is about 350 Sq Ft, its about 25 feet between the satellite(i have only one) and the router, diffrent floor though, but its a wired connection.
I have tried channel 1, 6 and 11 and auto on the 2,4Ghz band, and any unused channels on the 5Ghz.
I have 2 wifi neighbours, pretty close to my house, but their signals are weak in my house.
I have tried earlier to enable and disable beamforming, mimo and wmm, didnt change a thing either way, still drops the wifi.
But now i have done all the configuartions you suggested, the settings is saved and im gonna reboot both the satellite and the router, and i had wifi for about 6 minutes with this configuration.
Apr 22, 2019Guru - Experienced User
25 feet maybe a bit too close, If you can try the RBS a bit farther out.
If this still continues, try a full factory reset on the RBR and RBS and setup from scratch.
- gordongekkoApr 22, 2019AspirantI can Try that, but have the distance something to say when the connection between the router and the satelitte is wired?
I have factory reset the unites 2 times already.
This has to be a hw or sw failure with the ORBI system, lots of people have the same issues.- FURRYe38Apr 22, 2019Guru - Experienced User
The RBS is wired to the RBR? If so, how is it wired? Directly or thru a LAN switch?
Try the RBS wireless connected to the RBR, does it still happen?
Hasn't been a lot of people talking about this. Depends on how theres is configured and connected and distance as well. Too close even wired can cause problems.
- gordongekkoApr 22, 2019AspirantIts connected thru a lan switch, i can try to use the wireless connection between the router and satellite.
