sad39
Feb 17, 2020Tutor
Think I got scammed
Hi, I have been having a problem with my internet, and my ISP seemed to think it might be my router. This post isnt about that. I went to login to my router, and got a chat that offered help. No...
Feb 17, 2020Guru - Experienced User
Ya shouild not be going to any other sites when using orbilogin.com with 1 (i).
I would close all brosers and clear all browser caches. Use MalwareBytes and do a can of your PC or Laptops.
You can access the RBRs web page at 192.168.1.1 as well if your wanting to access it.
- sad39Feb 17, 2020Tutor
I dont know how i went to that wrong page... jittery typing hand or google autofill betrayed me... who knows... im a bonehead.
I have closed everything, and restarted my system...
I have since cleared the cache and history in my browser, run my antivirus scans (kaspersky), and am running malwarebytes now... I even activated the Netgear armor...
I am using a RBR50 with a satellite, using firmwar v2.3.5.30
The modem is an ARRIS DG1670A.
It drops out intermittently, as much as 4-10 times per day. I cannot link the outage to any specific usage patterns... happens when only 1 wired PC is being used, happens when the whole family is watching TV and playing video games...
- FURRYe38Feb 17, 2020Guru - Experienced User
Try a different browser or load up something different and use this one browser to manage the Orbi. Don't use it for anything else. I use Opera.
I see your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- sad39Feb 17, 2020Tutor
So... the ARRIS modem is supplied by my employer... I work from home...
As directed by my employer, the cable company had the wifi capabilities (and 3 of the 4 lan ports) disabled when it was installed.... so i think point 1 is covered.
