sad39
Feb 17, 2020Tutor
Think I got scammed
Hi, I have been having a problem with my internet, and my ISP seemed to think it might be my router. This post isnt about that. I went to login to my router, and got a chat that offered help. No...
Feb 17, 2020Guru - Experienced User
Try a different browser or load up something different and use this one browser to manage the Orbi. Don't use it for anything else. I use Opera.
I see your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
sad39
Feb 17, 2020Tutor
So... the ARRIS modem is supplied by my employer... I work from home...
As directed by my employer, the cable company had the wifi capabilities (and 3 of the 4 lan ports) disabled when it was installed.... so i think point 1 is covered.
- FURRYe38Feb 17, 2020Guru - Experienced User
Ok, just checking.
