SadToGo
Jun 11, 2020Aspirant
Thinking of getting an Orbi but worried...
Hi, I would like to set up a mesh WiFi network, but keep my existing Router for a large number of LAN connections. My set-up is a modem (input via FTTP), linked to a router (Asus RT-AX88U), a...
- Jun 11, 2020
You can do that.
I'm running a similar setup right now but with an RAX200 and not a Asus.
You might have misunderstood that you just need an Orbi router. Many think you can just use the satellites as access points but they need a router to coordinate/control them. The router has access point mode and is easy to put into it.
Jun 11, 2020Guru - Experienced User
You can do that.
- DarkNetJun 11, 2020Apprentice
Right. This is totally doable. Like the OP, my main concern was wifi coverage while keeping my own router (pfSense box). I got the ORBI 20 which came with the router unit and 2 satellites. I put the RBR20 into AP mode and then added the 2 satellites. Works perfectly now but I DID have an issue with the wifi cutting out which I resolved by removing one of the satellites. The satellite was not defective but apparently for the size of my house, 3 AP units was too much and caused outages due to oversaturation or something?? Anyway, I tried playing around with settings and then read of an end user with the same problem who removed a satellite to clear up the problem. It worked for me as well. My house is 2700sqft with an open floor plan and 3 AP units were too much for the space. Happily running the RBR20 and (1) RBS20 now with good coverage and no outages. Iâll keep the unused RBS20 for a replacement or if we move into a larger house đ
