superx3man
May 10, 2022Tutor
This happen very sudden like a week ago. Access was fine before.
Current state:
- 192.168.1.1 not accessible
- orbilogin.com not accessible
- https://192.168.1.1 not accessible
- http://192...
May 11, 2022Guru - Experienced User
What Orbi model do you have?
You'll need to factory reset the RBR by pressing the Reset button for 15 seconds then release. Connect a wired PC to the back of the RBR and setup from scratch using a wired PC and web browser at HTTP and 192.168.1.1 or orbilogin.com and walk thru the setup wizard. Do not attempt to use the orbi app for this. I would disconnect the RBR from the ISP modem/ont temporarily until you get thru the setup wizard.
Current state:
- http://192.168.1.1:5000/ result in a 404 not found
- ping 102.168.1.1 response CORRECTLY
- internet seems to be fine but a bit unstable.
- power cycled a few times (waited 10 minutes before restarting)
Is there anyway that i could avoid a factory reset, i have like 40 static ip setup that i'd want to avoid setting up again.
