007e
Feb 04, 2020Tutor
Throttling Devices - RBK53
Hello, I've read a few threads on here about throttling but was unable to get the info I need. Is it normal for the RBK50 series to throttle all my connected devices to approx 10-20Mbps? When I ...
- Feb 06, 2020
I re enabled WMM and it appears that did it.
I must have tested WMM on the old FW. It wasnt working very well with my ring cameras before hence the reason I had it off. It appears this new FW version is more stable, inclduing with the use of WMM,
For the record just in case anyone looks this up, here are my settings:
Disabled 20/40 MHz Coexistence
Enabled WMM (Wi-Fi multimedia) settings
Enabled Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enabled MU-MIMO
Disabled Fast-Roaming
Disabled Daisy-Chain Topology
Disabled Armor and Circle
I'm finally hitting up to 200+Mbps on my devices again.
Thanks for taking the time to help me out. I had tried these settings before but it helped going through it again.
CrimpOn
Feb 04, 2020Guru - Experienced User
This is not my experience. I pay Spectrum for 200mbs. Just now, the Speedtest app on my Sony smartphone registered 215mbs. Perhaps it would help to identify which devices record less bandwidth, and how it is being measured?
