007e
Feb 04, 2020Tutor
Throttling Devices - RBK53
Hello, I've read a few threads on here about throttling but was unable to get the info I need. Is it normal for the RBK50 series to throttle all my connected devices to approx 10-20Mbps? When I ...
- Feb 06, 2020
I re enabled WMM and it appears that did it.
I must have tested WMM on the old FW. It wasnt working very well with my ring cameras before hence the reason I had it off. It appears this new FW version is more stable, inclduing with the use of WMM,
For the record just in case anyone looks this up, here are my settings:
Disabled 20/40 MHz Coexistence
Enabled WMM (Wi-Fi multimedia) settings
Enabled Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enabled MU-MIMO
Disabled Fast-Roaming
Disabled Daisy-Chain Topology
Disabled Armor and Circle
I'm finally hitting up to 200+Mbps on my devices again.
Thanks for taking the time to help me out. I had tried these settings before but it helped going through it again.
CrimpOn
Feb 04, 2020Guru - Experienced User
This is not my experience. I pay Spectrum for 200mbs. Just now, the Speedtest app on my Sony smartphone registered 215mbs. Perhaps it would help to identify which devices record less bandwidth, and how it is being measured?
007e
Feb 04, 2020Tutor
Hey Crimpon thanks for replying. All my devices on my network get roughly 10-20Mbps wirelessly ( even next to the satellites and router). My go to is the Speedtest app. Ive speed tested Apple Tv's, iPhones, Ring Cameras, iPads, Smart TV's, Samsung Tablets, etc. They all register approx the same speeds. When using the Orbi app and running a speed test on the router gives me over 200Mbps.
- CrimpOnFeb 04, 2020Guru - Experienced User
What speed are you paying for?
Do you have a computer that can be connected to the router with ethernet to test with?
- 007eFeb 04, 2020Tutor
Paying for 200Mbps with Spectrum. Using their modem with the Orbi RBK53 from Costco. I dont currently have a way to test wired. This throttled User experience has been like this since day 2 (I vaguely remember getting full speeds on wireless devices the firs day or so). I've run a few diffrerent FW's and I'm currently on the most stable FW I've used to date, 2.5.1.8. No random lockups/dropouts with Orbi (requiring restarts). I have however restarted the Routers and Satellites, and even started from scratch after wiping them clean and setting them up from scratch.
I'm wondering If I just have a bad system.
- FURRYe38Feb 05, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how manyTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Turn OFF the two RBSs and work with just the RBR for now. Ensure wired LAN cable speedtesting is being used to test speeds first.
007e wrote:Paying for 200Mbps with Spectrum. Using their modem with the Orbi RBK53 from Costco. I dont currently have a way to test wired. This throttled User experience has been like this since day 2 (I vaguely remember getting full speeds on wireless devices the firs day or so). I've run a few diffrerent FW's and I'm currently on the most stable FW I've used to date, 2.5.1.8. No random lockups/dropouts with Orbi (requiring restarts). I have however restarted the Routers and Satellites, and even started from scratch after wiping them clean and setting them up from scratch.
