lifeandmylens
Dec 17, 2019Tutor
Throughput Tests While Roaming
Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi swee...
CrimpOn
Dec 17, 2019Guru - Experienced User
My experience has been that my Android smartphone and tablet took about 2 minutes to "Fast Roam" from router to satellite (and back). (Apparently two minutes is "fast". I did not experiment with Fast Roaming off.)
How long did you remain in one location before moving to the next location?
- lifeandmylensDec 17, 2019Tutor
Thanks. About 30-45 seconds in each room.
- Ragar99Dec 17, 2019Luminary
What version of the Router do you have, v1 or v2? Or does the Orbi router have a usb port on back?
Your numbers are pretty poor, I'd back up and test with nothing else running or streaming.
- CrimpOnDec 17, 2019Guru - Experienced User
lifeandmylens wrote:Thanks. About 30-45 seconds in each room.
It would be interesting to see "what happens" if you repeat the experiment and remain in a new location for over two minutes.
There is probably a fast roaming parameter that can be set using telnet commands, but I have never looked for one.
Walking around is one area where WiFi leaves a lot to be desired. We do a lot of Facetime with the grandkids (BEST invention EVER!) Yesterday, I wanted to show them something and went outside with my tablet. Walked about 50 ft. away from the house, and the connection dropped. Tablet doesn't have LTE (only WiFi), so I am "tethered" to the WiFi network.
Yes, FaceTime is great! We use it all the time. Its one of the things I am trying to improve, roaming and walking around the house while on a facetime call. Two minutes sounds like a lot!
CrimpOn wrote:My experience has been that my Android smartphone and tablet took about 2 minutes to "Fast Roam" from router to satellite (and back). (Apparently two minutes is "fast". I did not experiment with Fast Roaming off.)
There was not a lot of science in my Fast Roaming experiment. I opened the Orbi web interface and brought up "Attached Devices" on my Android tablet. Saw that I was attached to the router. Went downstairs and sat by the satellite watching the Attached Devices display update. Eventually, it said I was attached to the satellite. Maybe the actual time it takes to switch is less than two minutes. What I was trying to verify at the time is that devices actually do switch back and forth. And, at least some of them do.
- lifeandmylensDec 19, 2019TutorThanks all. I’m evaluating my placement to see if that’s affecting it. Does anyone have any recommendations on signal strength of the router on where to place the satellite (especially if hardwired)? Place it at -60, -75, -85 etc?
Also is it generally better practice to leave power levels of 5G alone or lower the power levels down and place additional satellites?- CrimpOnDec 19, 2019Guru - Experienced User
I think the key element is "hardwired". When using the 5G WiFi backhaul, I would want the satellite to be close enough for the Orbi to report the backhaul link as "Good" rather than "Poor". This means that the router and satellite user radios also are going to have "good signal" from the router when they are right next to the satellite. With two good signals to choose from, my guess is it doesn't matter which radio the user device picks. "Service is great. Enjoy it." Keeping the radio at full power allows service to extend farther in the direction away from the radio.
I would think that hardwired satellites can be placed quite a bit farther away than WiFi backhaul as long as that does not create "holes" in coverage. Consider having three Orbi units. On the left, each unit is close enough to have "Good" 5G backhaul, and many devices get good signal from more than one. On the right, using wired backhaul, they can be placed where user devices get "good" signal from only one Orbi. Total area covered with good signal is larger.
Of course, the physical layout of the building matter a lot. There's not a lot of purpose in providing good signal to locations where there are never any user devices. Many of us prefer to wire some of our user devices to Orbi ethernet ports, which also affects where the Orbi is placed.
