lifeandmylens
Dec 17, 2019Tutor
Throughput Tests While Roaming
Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi swee...
CrimpOn
Dec 17, 2019Guru - Experienced User
My experience has been that my Android smartphone and tablet took about 2 minutes to "Fast Roam" from router to satellite (and back). (Apparently two minutes is "fast". I did not experiment with Fast Roaming off.)
How long did you remain in one location before moving to the next location?
lifeandmylens
Dec 17, 2019Tutor
Thanks. About 30-45 seconds in each room.
- Ragar99Dec 17, 2019Luminary
What version of the Router do you have, v1 or v2? Or does the Orbi router have a usb port on back?
Your numbers are pretty poor, I'd back up and test with nothing else running or streaming.
- CrimpOnDec 17, 2019Guru - Experienced User
lifeandmylens wrote:Thanks. About 30-45 seconds in each room.
It would be interesting to see "what happens" if you repeat the experiment and remain in a new location for over two minutes.
There is probably a fast roaming parameter that can be set using telnet commands, but I have never looked for one.
Walking around is one area where WiFi leaves a lot to be desired. We do a lot of Facetime with the grandkids (BEST invention EVER!) Yesterday, I wanted to show them something and went outside with my tablet. Walked about 50 ft. away from the house, and the connection dropped. Tablet doesn't have LTE (only WiFi), so I am "tethered" to the WiFi network.
- lifeandmylensDec 17, 2019Tutor
Yes, FaceTime is great! We use it all the time. Its one of the things I am trying to improve, roaming and walking around the house while on a facetime call. Two minutes sounds like a lot!
