lifeandmylens
Dec 17, 2019Tutor
Throughput Tests While Roaming
Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi swee...
Dec 17, 2019Guru - Experienced User
What happpens with Beamforming enabled?
V2.5.1.8 is now avaialable FYI.
lifeandmylens wrote:Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi sweet spots as the app and 10 seconds average measurement in each spot.
I have:
A 6500 sq ft house.
ATT fiber 1gbps service
A BGW210 Modem/Router
1 RBR50 in AP Mode
3 RBS50's all hardwired via Cat5e, 40-50 feet in between units.
Settings:
CTS/RTS Threshold (1-2347) 2347
Enable WMM (Wi-Fi multimedia) settings - enabled
Enable 20/40 MHz Coexistence - enabled
2.4 Transmit Power Control - 75%
5 Transmit Power Control - 100%
Enable MU-MIMO - enabled
Enable Daisy-Chain Topology - off
Enable Fast Roaming - on
Enable Implicit BEAMFORMING - off
Running V2.3.5.30, after a clean reset and setup again.
Would love some input on these numbers and Orbi's lack of ability to roam and maintain throughput with mulitple streams. And any suggestion changes I could make to improve things.
