lifeandmylens
Dec 17, 2019Tutor
Throughput Tests While Roaming
Please see attached. It was a real world test as I had two Apple TV's streaming YouTubeTV while doing this test, and wife browsing web pages. The test device was an iPhone 11 Pro Max with wifi swee...
lifeandmylens
Dec 17, 2019Tutor
FURRYe38 wrote:What happpens with Beamforming enabled?
V2.5.1.8 is now avaialable FYI.
Thanks, I am updating now to the new firmware and will test again. I am happy to try beamforming, but I believe implicit is for order devices, and explicit is enabled by default.
Dec 17, 2019Guru - Experienced User
Order devices?
You might try both enabled and disabled to compare results.
- lifeandmylensDec 17, 2019TutorSorry I meant older :)
- FURRYe38Dec 17, 2019Guru - Experienced User
Try both to compare.
