mokolabs
Jan 01, 2017Tutor
Time Capsule on Orbi?
Just curious... has anyone gotten their Airport Time Capsule to work on Orbi yet? Or, more generally, is anyone using Time Machine with Orbi? I've got my Time Capsule hooked up to the Orbi satell...
Random12
Jan 12, 2017Apprentice
I don't thinkt the issue is related to Orbi, it might be a time capsule configuration issue. It seems Apple doesn't officially support time capsule backup over a different (non Apple) wireless network. Some people seem to have made it work. Search over in here for more information:
Also, google for "time capsule with another wireless router" there seems to be lots of threads about it on the internet. Some of them seem a bit confusing, hopfully you find the solution.
Hope this helps.
mokolabs
Jan 16, 2017Tutor
Thanks. Maybe you're right. Maybe it just doesn't work anyway, so it's not Orbi's fault.
