mokolabs
Jan 01, 2017Tutor
Time Capsule on Orbi?
Just curious... has anyone gotten their Airport Time Capsule to work on Orbi yet? Or, more generally, is anyone using Time Machine with Orbi? I've got my Time Capsule hooked up to the Orbi satell...
mokolabs
Jan 16, 2017Tutor
So are you saying that you did not connect the Time Capsule directly to the Orbi? That it was connected via a separate ethernet switch?
saronian
Jan 16, 2017Star
I consider it connected directly to the Orbi via Etrhernet but wanted to offer that there is a simple Netgear switch inbetween. So technically the Ethernet wire isn't a direct run to Orbi's port. But it shouldn't make a difference in opereation. The key to getting the Time Capsule working over WiFi is to disable WiFi in the Time Capsuyle and also place it in Bridge mode.
With this configuration Time Machine will backup over Orbi's WiFi.
