bmws88
Nov 02, 2020Aspirant
Time, DST and Schedule
There is a thread on how to set time zone. It says Advanced-Security-Schedule then drop-down. It is obsolete. The setting is in NTP. You guys need to remove obsolete threads. It is wasting my time. ...
Nov 02, 2020Guru - Experienced User
What region are you located? Most of US region, there was a time change backwards 1 hour this weekend. Make sure your router has updated time. Power cycle the ISP modem and RBR.
NTP settings can be found under Advanced Tab/Administration/NTP Settings. Be sure your time zone is correct and that "Automatically adjust for daylight savings time" is enabled. Make sure the time here is correctly seen on your router.
- bmws88Nov 02, 2020Aspirant
The time change hiccup piece was wrong. My bad. My son said it didn't work. It worked properly, just not long enough for him.
Once I saw the mention of NTP in another thread, it was easy to know where it is. Otherwise, how am I supposed to know what NTP is and that timezone would be under NTP when the confirmed solution says it is under Schedule? You guys need a way for users to feedback obsolete solutions.
How to block service from 11PM-5AM?
- FURRYe38Nov 02, 2020Guru - Experienced User
- CrimpOnNov 02, 2020Guru - Experienced User
bmws88 wrote:Once I saw the mention of NTP in another thread, it was easy to know where it is. Otherwise, how am I supposed to know what NTP is and that timezone would be under NTP
Configuring computer device the first time is often confusing. Everything I have ever set up in over 20 years have Time Zone as part of Network Time Protocol (NTP) setup. Future device configurations will be easier.
bmws88 wrote:You guys need a way for users to feedback obsolete solutions.
The only people who can edit or erase forum posts are the forum moderators. (Users with that "capital N" aftet their screen name.) Click on the screen name and send a private message to one of them with the link to the invalid information.
