Hammyhouse
Jul 11, 2021Tutor
Time to upgrade?
Hello all, wants to say thanks first for the the advice. I currently have the rbk50 setup with 3 decent gaming PCs and 2 playstations along with a bunch of smart devices, ring package (alarm camera). ...
- Jul 26, 2021
As plemans suggested and gave info. May not be worth it, and if your ISP is Spectrum, they are hard to deal with when it comes to user owned modems. So if you run into problems with your own modem, good luck in dealing with Spectrum. It would be best to use one of there modem only units. I would recommend the CM1200 as I enjoy mine, however don't have Spectrum. Experiences differ with different ISPs. If Orbi 50 series is stable and working well for you, use it until such time as you see fit to get into something else.
Please mark your thread as solved so others will know.
Enjoy.
Hammyhouse wrote:Okay so i did a firmware update , made some changes i found throught the community. (fast roaming turned off etc.) seems to be alot more stable. Im pulling 495 down and 20 up off a 400/20 service (spectrum).
Now with all said would you see a reason to upgrade anything in my network? Orbi is 2 years old working fine though. I have some reward points to use and can get the cm1200 modem over provider modem but is it really worth it?
I do plan on adding some more smart device but the rbk50 states it can handle a decent amount of devices.
Thanks for your input.
Jul 11, 2021Guru - Experienced User
do you have the option of hardwiring in some devices?
Either to the satellites or router?
If you do, then do so first. Wired is much faster, lower latency and will take some of the burden off the wifi.
Even hardwiring some devices into the satellites help as the satellites have the wider 1733mbps backhaul with the 50 series of mesh.
Its a solid system.
- HammyhouseJul 11, 2021TutorYes, so I have two of the computers and a PlayStation hard wired to the rbr50 and I have another pc hooked up via wire thru the rbs50, everything else obviously is WiFi.
It’s the random drops or lag out that kills me.- FURRYe38Jul 11, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- HammyhouseJul 11, 2021TutorYes I just saw the thread on some settings. Right now I’m on .104 was gonna update to the latest , looks like I’m one behind. Gonna check setting and report back.
Using spectrum /charter service and modem model is e31u2v1
