staggerlee42
Mar 22, 2020Aspirant
time zone changes repeatedly, causing connectivity issues - Orbi RBS50
Intermittently I randomly become unable to access Netflix / Amazon prime or develop other miscellaneous connectivity issues. When logging in to my Orbi I will often see the timezone has changed. I li...
staggerlee42
Thanks, had a look into this and locked my phone's timeline to London. Then this evening at 11pm same thing happened again, casablanca again! Also had not used the orbi iPhone app again during this period.
Any other ideas?
It says you can use a "preferred NTP server", don't really understand this well enough but could that be a potential fix? Could anyone talk me through setting this up?
Thanks again
Mar 22, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update on the RBR?
staggerlee42 wrote:Thanks, had a look into this and locked my phone's timeline to London. Then this evening at 11pm same thing happened again, casablanca again! Also had not used the orbi iPhone app again during this period.
Any other ideas?
Thanks again
- CrimpOnMar 22, 2020Guru - Experienced User
What an exotic life you Brits have! Could you please check the setting on the Orbi web interface, Advanced Tab, Wireless Settings.
What "Region" does it say you are in?
- staggerlee42Mar 23, 2020Aspirant
Europe
No I have never done a factory reset. This was an issue and I updated the firmware to see if it would help (it did not!)
Is this something you would recommend? Can you link to an idiot-proof guide for performing a reset if you thint its the way forward?
Thanks
- FURRYe38Mar 23, 2020Guru - Experienced User
Let try a reset:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
staggerlee42 wrote:No I have never done a factory reset. This was an issue and I updated the firmware to see if it would help (it did not!)
Thanks
