geneousgene
Sep 26, 2017Aspirant
timeouts pinging router while plugged into satellite ethernet
Apologize in advance for a semi-duplicitious post. In trying to figure out internet latency problems, I've narrowed down my issues to the Orbi Roter. I am connected to a satellite via ethernet a...
aaz
Sep 26, 2017Virtuoso
You have some seriously large latency. In one of the threads someone mentioned the router CPU running excessivly high. Something on your network may be causing it. Considering you had the same issue when wired to the router means it's not a wifi interference issue - correct?
It certainly sounds like you need a call into support to diagnose this.
But I would also make sure to turn off UPnP as it caused a similar issue for me.
