dogmatix
Jun 26, 2017Aspirant
Tivo gets 2 IP addresses on Orbi
I have 2 Tivo boxes connecting to the Orbi routers via the Tivo Wireless N adapter. I have configured the Tivo boxes to use static IP and I have reserved those IPs on the Orbi with mac address reserv...
st_shaw
Jun 26, 2017Master
dogmatix wrote:I have 2 Tivo boxes connecting to the Orbi routers via the Tivo Wireless N adapter. I have configured the Tivo boxes to use static IP and I have reserved those IPs on the Orbi with mac address reservation.
The Tivo Wireless N adapter is an Ethernet to WiFi bridge--it connects to the wired Ethernet port on Tivo and provides a WiFi connection. I have seen wireless bridges like this pull two IP address--one for the wired device, and one for the adapter itself. Your issue is almost certainly with the Wireless N adapter. The adapters themselves have settings. Google it and review the user guide documents to make sure the adapters are setup properly. Or connect the Tivos with wired Ethernet.
If everything is setup correctly the multiple IP address should not cause you any issues. However, if you happen to be assiging static IPs on any devices themselves, and are using addresses that are inside the DHCP range of the router, you will cause problems.
- dogmatixJun 27, 2017Aspirant
Thanks - I was aware of this Ethernet to Wifi model on the Tivo Wireless N. I have seen it pull 2 IPs at the time of restart, but the adapter IP disappears from the DHCP table. For some reason, both of them get the IP with the same Mac address. I expected them to have different Macs when they got the IP from the router.
In any case, I have reset the adapter on both boxes, and have now set mac address reservation only on the router and left the Tivo setting to use DHCP. Will let this thread know if that solves the issue.
- dogmatixJul 02, 2017Aspirant
I did the following and it seems to have fixed the issue.
1. Reset Tivo to use DHCP and not Static IP.
2. Reserved IP against Tivo Mac Addresses on Orbi.
3. Stopped Tivos.
4. Restarted Orbi
5. Started each Tivo in sequence.
The only odd behavior I still see is that Orbi seems to give our duplicate IPs for the same Mac for the Tivos from time to time. The duplicates seem to disappear and reappear over the course of 24 hours. It has not affected the tivos from talking to each other or streaming from the internet. However, I do find it puzzling.
- dogmatixJul 04, 2017Aspirant
The duplicate IPs despite a mac address reservation at the route is still there. Any suggestions on how to debug? The only behavior I can see which is consistent is that this happens only when the Tivo is connected to the satellites instead of the main router.
