dogmatix
Jun 26, 2017Aspirant
Tivo gets 2 IP addresses on Orbi
I have 2 Tivo boxes connecting to the Orbi routers via the Tivo Wireless N adapter. I have configured the Tivo boxes to use static IP and I have reserved those IPs on the Orbi with mac address reserv...
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello dogmatix
You can check the attached devices on each satellite by using the satellites Ip address in your web browser this will tell you only the devices attached to that unit.
DarrenM
dogmatix
Jul 07, 2017Aspirant
Hi Darren,
I have done what you suggested. In fact the duplicate IPs for the same mac address are showing up on the same satellite. I am wondering why Orbi is assigning a a second IP that is not the reserved IP for a Tivo which has mac address reservation.
Shankar
